Hello
Grafana 8.0.5
Problem with a Table Panel, the place the Distance are, as soon i add a specifig FrameNumber Field the Distance Panel Graphe is not working.
but have a look at the picture
This is how it should be
then i do add the FrameNumber and got this destroyed gradient gauge
Adding other Fields are not doing this problem!
