Add years to date value
Hello community,
I need your help for transform data/date.
In grafana, I have a date value (DD/MM/YYYY), I would like to add 2 years to this date (18/04/2022 → 18/04/2024).
What I can do ?
Thank you for your help
Anthony
When you say “In Grafana, I have a date value”, where does this date come
from?
Is it from some query on your back-end data source (if so, what is that data
source?) or is it from your time picker in Grafana, or… what?
Antony.
Thank you for your reply.
The value comes from zabbix which monitor a UPS (BatteryLastReplacedDate).
I just apply time unit (time:DD/MM/YYYY) by default the value is MM/DD/YYYY.
Now I would like to add 2 years to this date to display the batterie replacement date (+ 2 years or 48 months).
You can add 63072000000 (60(s)*60(m)*24(h)*365(d)21000(ms))
to your existing date, this wont be accurate on leap years…
Great, it’s perfect !
Thank you very much :+1:
