Add userid to within plugin
Is there a way to get the grafana user id from within a plugin?
What type of plugin are you building? Are you looking for a TypeScript or a Go solution?
Good question. I don’t know. Looking to modify an existing plugin. How can I tell?
Right now, I see my userid being discovered as the cookie ie.
You can get it from the User model
import { config } from '@grafana/runtime';
console.log(config.bootData.user);
