Add 1 month to a time with a transformation
    v9
    I would like to link to a dashboard that display 1 month of daily data starting from a panel with monthly data.
    I tried different things, for instance working with from and to variables, but I’m unable to add 1 month to the to variable.
So? I’m trying to add a new field with the To variable already evaluated in the query in a transform operation, but without success for the moment.
  • What happened?
    The value is not evaluated with 1 month added.
Thanks
Did you try Query options?
Query options
No, I tried to change the date range in the time picker with the variables from and to, from a datalink.
I am able to set FROM with the correct timestamp, but are not able to set TO with FROM + 1 month,
