I have been using a Grafana Cloud Dashboard with a Postgres DB and a binary PDC since a couple of weeks. Lately I can not connect to the Postgres datasource anymore. It tells me “There was an error when testing this data source, please check PDC agent logs.” and “Acess denied.”.
The PDC log tells me:
level=info caller=main.go:119 ts=2024-10-28T09:45:08.2685647+01:00 msg="PDC agent info" version=v0.0.33 commit=85209683333c8de3d6b919451b9349ace029dc3c date=2024-09-05T11:32:36Z sshversion="OpenSSH_for_Windows_9.5p1, LibreSSL 3.8.2\r" os=windows arch=amd64 level=info caller=ssh.go:142 ts=2024-10-28T09:45:08.3529614+01:00 msg="starting ssh client" level=warn caller=ssh.go:343 ts=2024-10-28T09:45:08.3830853+01:00 msg="unable to retrieve SSH version for validation" err="failed to parse OpenSSH version" level=debug caller=keymanager.go:55 ts=2024-10-28T09:45:08.3847497+01:00 msg="starting key manager" level=debug caller=keymanager.go:220 ts=2024-10-28T09:45:08.3868404+01:00 msg="found existing valid certificate" level=debug caller=keymanager.go:233 ts=2024-10-28T09:45:08.3873647+01:00 msg="found valid grafana_pdc_known_hosts" level=debug caller=ssh.go:167 ts=2024-10-28T09:45:08.3889285+01:00 msg="parsed flags: [-i C:\\Users\\s2976230/.ssh/grafana_pdc 1028610@private-datasource-connect-prod-eu-west-2.grafana.net -p 22 -R 0 -o CertificateFile=C:\\Users\\s2976230/.ssh/grafana_pdc-cert.pub -o ConnectTimeout=1 -o ServerAliveInterval=15 -o UserKnownHostsFile=C:\\Users\\s2976230/.ssh/grafana_pdc_known_hosts -vvv]" level=info caller=metrics.go:31 ts=2024-10-28T09:45:08.3894521+01:00 msg="Starting serving metrics" addr=:8090 level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4109009+01:00 msg="OpenSSH_for_Windows_9.5p1, LibreSSL 3.8.2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4214833+01:00 msg="debug3: Failed to open file:C:/Users/s2976230/.ssh/config error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4220056+01:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_config error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4340261+01:00 msg="debug2: resolving \"private-datasource-connect-prod-eu-west-2.grafana.net\" port 22" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4340261+01:00 msg="debug3: resolve_host: lookup private-datasource-connect-prod-eu-west-2.grafana.net:22" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4460566+01:00 msg="debug3: ssh_connect_direct: entering" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4562673+01:00 msg="debug1: Connecting to private-datasource-connect-prod-eu-west-2.grafana.net [52.59.18.83] port 22." level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4567939+01:00 msg="debug2: fd 3 setting O_NONBLOCK" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4688799+01:00 msg="debug1: fd 3 clearing O_NONBLOCK" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.476861+01:00 msg="debug1: Connection established." level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4779212+01:00 msg="debug3: timeout: 989 ms remain after connect" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4794956+01:00 msg="debug1: identity file C:\\\\Users\\\\s2976230/.ssh/grafana_pdc type 3" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4821067+01:00 msg="debug1: certificate file C:\\\\Users\\\\s2976230/.ssh/grafana_pdc-cert.pub type 7" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4826449+01:00 msg="debug1: Local version string SSH-2.0-OpenSSH_for_Windows_9.5" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4932087+01:00 msg="debug1: Remote protocol version 2.0, remote software version Go" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4937453+01:00 msg="debug1: compat_banner: no match: Go" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4942697+01:00 msg="debug2: fd 3 setting O_NONBLOCK" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4947981+01:00 msg="debug1: Authenticating to private-datasource-connect-prod-eu-west-2.grafana.net:22 as '1028610'" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4958281+01:00 msg="debug3: record_hostkey: found ca key type RSA in file C:\\\\Users\\\\s2976230/.ssh/grafana_pdc_known_hosts:1" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4965959+01:00 msg="debug3: load_hostkeys_file: loaded 1 keys from private-datasource-connect-prod-eu-west-2.grafana.net" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4971276+01:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4976497+01:00 msg="debug1: load_hostkeys: fopen __PROGRAMDATA__\\\\ssh/ssh_known_hosts: No such file or directory" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4981672+01:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts2 error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4986903+01:00 msg="debug1: load_hostkeys: fopen __PROGRAMDATA__\\\\ssh/ssh_known_hosts2: No such file or directory" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4992121+01:00 msg="debug3: order_hostkeyalgs: prefer hostkeyalgs: ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4997424+01:00 msg="debug3: send packet: type 20" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.4997424+01:00 msg="debug1: SSH2_MSG_KEXINIT sent" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5002686+01:00 msg="debug3: receive packet: type 20" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5007946+01:00 msg="debug1: SSH2_MSG_KEXINIT received" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5013162+01:00 msg="debug2: local client KEXINIT proposal" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5018388+01:00 msg="debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,ext-info-c,kex-strict-c-v00@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5023632+01:00 msg="debug2: host key algorithms: ssh-ed25519-cert-v01@openssh.com,ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,sk-ssh-ed25519-cert-v01@openssh.com,sk-ecdsa-sha2-nistp256-cert-v01@openssh.com,rsa-sha2-512-cert-v01@openssh.com,rsa-sha2-256-cert-v01@openssh.com,ssh-ed25519,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,rsa-sha2-512,rsa-sha2-256" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5028856+01:00 msg="debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5034081+01:00 msg="debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5039297+01:00 msg="debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5044517+01:00 msg="debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5044517+01:00 msg="debug2: compression ctos: none,zlib@openssh.com,zlib" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5049841+01:00 msg="debug2: compression stoc: none,zlib@openssh.com,zlib" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5055211+01:00 msg="debug2: languages ctos: " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5077638+01:00 msg="debug2: languages stoc: " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5077638+01:00 msg="debug2: first_kex_follows 0 " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5088162+01:00 msg="debug2: reserved 0 " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5093412+01:00 msg="debug2: peer server KEXINIT proposal" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5098652+01:00 msg="debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,kex-strict-s-v00@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5098652+01:00 msg="debug2: host key algorithms: ssh-ed25519-cert-v01@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5103872+01:00 msg="debug2: ciphers ctos: aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5109191+01:00 msg="debug2: ciphers stoc: aes128-gcm@openssh.com,aes256-gcm@openssh.com,chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5114404+01:00 msg="debug2: MACs ctos: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5119624+01:00 msg="debug2: MACs stoc: hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1,hmac-sha1-96" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5124838+01:00 msg="debug2: compression ctos: none" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5130152+01:00 msg="debug2: compression stoc: none" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5130152+01:00 msg="debug2: languages ctos: " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.513539+01:00 msg="debug2: languages stoc: " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5140584+01:00 msg="debug2: first_kex_follows 0 " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5145782+01:00 msg="debug2: reserved 0 " level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5145782+01:00 msg="debug3: kex_choose_conf: will use strict KEX ordering" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5151169+01:00 msg="debug1: kex: algorithm: curve25519-sha256" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5156357+01:00 msg="debug1: kex: host key algorithm: ssh-ed25519-cert-v01@openssh.com" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5161545+01:00 msg="debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5161545+01:00 msg="debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5172007+01:00 msg="debug3: send packet: type 30" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.51772+01:00 msg="debug1: expecting SSH2_MSG_KEX_ECDH_REPLY" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.529261+01:00 msg="debug3: receive packet: type 31" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5369749+01:00 msg="debug1: SSH2_MSG_KEX_ECDH_REPLY received" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5380245+01:00 msg="debug1: Server host certificate: ssh-ed25519-cert-v01@openssh.com SHA256:BTprSocrteTh4Tc5SZShxsrDsGN3eJqDpc3m8JqPaRU, serial 0 ID \"\" CA ssh-rsa SHA256:4LYaBFs+5Wkg/bloCsRDJIsox93GC0tShMBQ0j5HRnY valid forever" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5385483+01:00 msg="debug2: Server host certificate hostname: private-datasource-connect-prod-eu-west-2.grafana.net" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.539613+01:00 msg="debug3: record_hostkey: found ca key type RSA in file C:\\\\Users\\\\s2976230/.ssh/grafana_pdc_known_hosts:1" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5401428+01:00 msg="debug3: load_hostkeys_file: loaded 1 keys from private-datasource-connect-prod-eu-west-2.grafana.net" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5406683+01:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5411917+01:00 msg="debug1: load_hostkeys: fopen __PROGRAMDATA__\\\\ssh/ssh_known_hosts: No such file or directory" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5417189+01:00 msg="debug3: Failed to open file:C:/ProgramData/ssh/ssh_known_hosts2 error:2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5422522+01:00 msg="debug1: load_hostkeys: fopen __PROGRAMDATA__\\\\ssh/ssh_known_hosts2: No such file or directory" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5427758+01:00 msg="debug1: Host 'private-datasource-connect-prod-eu-west-2.grafana.net' is known and matches the ED25519-CERT host certificate." level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5427758+01:00 msg="debug1: Found CA key in C:\\\\Users\\\\s2976230/.ssh/grafana_pdc_known_hosts:1" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.545919+01:00 msg="debug3: send packet: type 21" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.546977+01:00 msg="debug1: ssh_packet_send2_wrapped: resetting send seqnr 3" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5475027+01:00 msg="debug2: ssh_set_newkeys: mode 1" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5480276+01:00 msg="debug1: rekey out after 134217728 blocks" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5485607+01:00 msg="debug1: SSH2_MSG_NEWKEYS sent" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5490812+01:00 msg="debug1: expecting SSH2_MSG_NEWKEYS" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.549606+01:00 msg="debug3: receive packet: type 21" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5501284+01:00 msg="debug1: ssh_packet_read_poll2: resetting read seqnr 3" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5506558+01:00 msg="debug1: SSH2_MSG_NEWKEYS received" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5511855+01:00 msg="debug2: ssh_set_newkeys: mode 0" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5511855+01:00 msg="debug1: rekey in after 134217728 blocks" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5517127+01:00 msg="debug3: ssh_get_authentication_socket_path: path '\\\\\\\\.\\\\pipe\\\\openssh-ssh-agent'" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5522372+01:00 msg="debug3: unable to connect to pipe \\\\\\\\.\\\\pipe\\\\openssh-ssh-agent, error: 2" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5527585+01:00 msg="debug1: get_agent_identities: ssh_get_authentication_socket: No such file or directory" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.55328+01:00 msg="debug1: Will attempt key: C:\\\\Users\\\\s2976230/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I explicit" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5538011+01:00 msg="debug1: Will attempt key: C:\\\\Users\\\\s2976230/.ssh/grafana_pdc ED25519 SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I explicit" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.554333+01:00 msg="debug2: pubkey_prepare: done" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.554333+01:00 msg="debug3: send packet: type 5" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5548539+01:00 msg="debug3: receive packet: type 7" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5553805+01:00 msg="debug1: SSH2_MSG_EXT_INFO received" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5559393+01:00 msg="debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,sk-ecdsa-sha2-nistp256@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,rsa-sha2-256,rsa-sha2-512,ssh-rsa,ssh-dss>" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.5576696+01:00 msg="debug1: kex_ext_info_check_ver: ping@openssh.com=<0>" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6237343+01:00 msg="debug3: receive packet: type 6" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6281367+01:00 msg="debug2: service_accept: ssh-userauth" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6292273+01:00 msg="debug1: SSH2_MSG_SERVICE_ACCEPT received" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6297534+01:00 msg="debug3: send packet: type 50" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6408636+01:00 msg="debug3: receive packet: type 51" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6487715+01:00 msg="debug1: Authentications that can continue: publickey" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6491675+01:00 msg="debug3: start over, passed a different list publickey" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6496942+01:00 msg="debug3: preferred publickey,keyboard-interactive,password" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.650216+01:00 msg="debug3: authmethod_lookup publickey" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6507428+01:00 msg="debug3: remaining preferred: keyboard-interactive,password" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6512651+01:00 msg="debug3: authmethod_is_enabled publickey" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6517873+01:00 msg="debug1: Next authentication method: publickey" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6523115+01:00 msg="debug1: Offering public key: C:\\\\Users\\\\s2976230/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I explicit" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6523115+01:00 msg="debug3: send packet: type 50" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6528374+01:00 msg="debug2: we sent a publickey packet, wait for reply" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6717376+01:00 msg="debug3: receive packet: type 60" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6722753+01:00 msg="debug1: Server accepts key: C:\\\\Users\\\\s2976230/.ssh/grafana_pdc-cert.pub ED25519-CERT SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I explicit" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6728143+01:00 msg="debug3: sign_and_send_pubkey: using publickey with ED25519-CERT SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6733532+01:00 msg="debug2: sign_and_send_pubkey: using private key \"C:\\\\Users\\\\s2976230/.ssh/grafana_pdc\" for certificate" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6749735+01:00 msg="debug3: sign_and_send_pubkey: signing using ssh-ed25519-cert-v01@openssh.com SHA256:QmU/T/5Rxz0BomVadGGRYYcKKGmUIsGjB6UQpHSJt5I" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6802692+01:00 msg="debug3: send packet: type 50" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.698529+01:00 msg="debug3: receive packet: type 52" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6995931+01:00 msg="Authenticated to private-datasource-connect-prod-eu-west-2.grafana.net ([52.59.18.83]:22) using \"publickey\"." level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.6995931+01:00 msg="debug1: Remote connections from LOCALHOST:0 forwarded to local address socks:0" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7001158+01:00 msg="debug3: send packet: type 80" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7006386+01:00 msg="debug2: fd 5 setting O_NONBLOCK" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7011442+01:00 msg="debug2: fd 6 setting O_NONBLOCK" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7011646+01:00 msg="debug1: channel 0: new session [client-session] (inactive timeout: 0)" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7016884+01:00 msg="debug3: ssh_session2_open: channel_new: 0" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7022089+01:00 msg="debug2: channel 0: send open" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7027135+01:00 msg="debug3: send packet: type 90" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.702731+01:00 msg="debug1: Entering interactive session." level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7032499+01:00 msg="debug1: pledge: network" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7037701+01:00 msg="debug3: client_repledge: enter" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7042926+01:00 msg="debug1: ENABLE_VIRTUAL_TERMINAL_INPUT is supported. Reading the VTSequence from console" level=info caller=ssh.go:324 ts=2024-10-28T09:45:08.7048147+01:00 msg="debug3: This windows OS supports conpty"
Any ideas for troubleshooting?
