A question around multi platform monitoring
Hi All
Just a quick question. I currently use Grafana Open Source to display Nagios graphs and various other info from Nagios. We currently have a big project on which involves monitoring from various sources, all of which can’t be done by Nagios. If the outcome of the question is what i am hoping, then we will be looking into purchasing Grafana Enterprise as we will require support due the importance of the alerting that needs to be done. So my question is this…
Would it be possible to monitor Dynamics FO (Finance and Operations) / CRM, Azure, and On-Prem Nagios, all under one Dashboard, with the possibility of drilling down into issues?
I am aware there are Azure plugin’s, are there also plugins for Dynamics?
