A question about the toolbar
When I enter the dashboard, there is a value in the Filters section that is causing some problems:
Toolbar
How can I change the default value of this section?
Thank you.
witch value?
you can control your values in the url…
d/id/dashboardname?var-JOB=…&var-hostnane=…&var-instance&var-Filters=…
Thank you so much for your reply.
The name of one of my servers is always in the Filters section. Is it normal?
Have you saved your dashboard with empty variables?
Thank you so much.
