I have a log record that is a CEF record with a couple of fields that are JSON. Is there an example of how I would extract the fields from the JSON record when most of the record is CEF?
Hi @kleewyck ,
maybe this will help
I have some logs from a demo app that look like this
2021-12-13T14:26:59.370Z INFO frontend/best_eta.go:106 Dispatch successful {"service": "frontend", "trace_id": "62c43baab1d3ba01", "span_id": "62c43baab1d3ba01", "driver": "T729032C", "eta": "2m0s"}
I can get to the JSON object at the end with this query
{container="hotrod"} | pattern "<time>\t<level>\t<component>\t<status>\t<json_log>\n" | line_format "{{.json_log}}"
I first split the log message using \t
as the separator. Then I can take the json_log
filed and apply line_format
to it. Not sure if this is the beat way to do it but it seems to work…
Thank you very much. This might work in my case!
