500 errors in Loki Distributor pods with no description
Hi team,
We have a pretty high loaded distributed Loki deployment deployed using Helm charts on OpenShift cluster.
We see a lot of 500 errors without actual details like this in our Loki Distributor pods:
level=warn caller=logging.go:142 msg=“POST /loki/api/v1/push (500) 136.58547ms”
Also we see the error in our loki-gateway nginx logs like this:
admin [30/Sep/2025:09:58:45 +0000] 500 “POST /loki/api/v1/push HTTP/1.1” 104 “-” “Vector/0.46.1 (x86_64-unknown-linux-gnu 9a19e8a 2025-04-14 18:36:30.707862743)” “-”
We don’t actually notice any troubles with the ingester pods, we have 3 pods running
And seems like this causes some missing logs issues.
We use Vector as a source for Loki and AWS S3 bucket as a destination.
We tried to increase the debug level but still dont see any details about the error.
Can you please help to figure out the excact cause of the problem
Our Loki config:
deploymentMode: Distributed
gateway:
image:
registry: quay.io
repository: nginx/nginx-unprivileged
tag: 1.24-alpine
nginxConfig:
resolver: “dns-default.openshift-dns.svc.cluster.local.”
loki:
auth_enabled: true
commonConfig:
path_prefix: /var/loki
storage:
type: s3
schemaConfig:
configs:
    store: tsdb
    object_store: s3
    schema: v13
    index:
    prefix: loki_index_
    period: 24h
    compactor:
    working_directory: /var/loki/compactor
podSecurityContext:
runAsNonRoot: false
allowPrivilegeEscalation: false
containerSecurityContext:
runAsNonRoot: false
capabilities:
drop:
  • ALL
    readOnlyRootFilesystem: true
test:
enabled: false
sidecar:
rules:
enabled: false
datasources:
enabled: false
singleBinary:
replicas: 0
backend:
replicas: 0
read:
replicas: 0
write:
replicas: 0
bloomPlanner:
replicas: 0
bloomBuilder:
replicas: 0
bloomGateway:
replicas: 0
lokiCanary:
enabled: false
ruler:
enabled: false
global:
extraArgs:
  • “-log.level=debug”
gateway:
service:
type: LoadBalancer
resources:
requests:
cpu: 100m
memory: 128Mi
limits:
memory: 256Mi
loki:
commonConfig:
replication_factor: 3
storage:
type: s3
s3:
region: us-east-1
storage_config:
aws:
region: us-east-1
s3forcepathstyle: false
limits_config:
retention_period: 744h # 31 days retention
ingestion_rate_mb: 100
ingestion_burst_size_mb: 300
ingestion_rate_strategy: “local”
max_streams_per_user: 0
max_line_size: 2097152
per_stream_rate_limit: 100M
per_stream_rate_limit_burst: 400M
reject_old_samples: false
discover_service_name:
discover_log_levels: false
volume_enabled: true
max_global_streams_per_user: 75000
max_entries_limit_per_query: 100000
increment_duplicate_timestamp: true
allow_structured_metadata: true
runtimeConfig:
configs:
log_stream_creation: true
log_push_request: true
log_push_request_streams: true
log_duplicate_stream_info: true
ingester:
chunk_target_size: 8388608 # 8MB
chunk_idle_period: 5m
max_chunk_age: 2h
chunk_encoding: snappy # Compress data (reduces S3 transfer size)
chunk_retain_period: 1h # Keep chunks in memory after flush
flush_op_timeout: 10m # Add timeout for S3 operations
querier:
max_concurrent: 8
query_range:
parallelise_shardable_queries: true
ingester:
replicas: 3
autoscaling:
enabled: true
zoneAwareReplication:
enabled: true
maxUnavailable: 1
resources:
requests:
cpu: 500m
memory: 1Gi
limits:
cpu: 2000m
memory: 2Gi
persistence:
enabled: true
affinity: {}
podAntiAffinity:
soft: {}
hard: {}
querier:
replicas: 3
autoscaling:
enabled: true
maxUnavailable: 1
resources:
requests:
cpu: 300m
memory: 512Mi
limits:
memory: 1Gi
affinity: {}
queryFrontend:
replicas: 2
maxUnavailable: 1
resources:
requests:
cpu: 200m
memory: 256Mi
limits:
memory: 512Mi
queryScheduler:
replicas: 2
maxUnavailable: 1
resources:
requests:
cpu: 200m
memory: 256Mi
limits:
memory: 512Mi
distributor:
replicas: 5
autoscaling:
enabled: true
minReplicas: 5
maxReplicas: 10
targetCPUUtilizationPercentage: 70
maxUnavailable: 1
resources:
requests:
cpu: 500m
memory: 1Gi
limits:
memory: 2Gi
affinity: {}
compactor:
replicas: 1
retention_enabled: true
retention_delete_delay: 2h
retention_delete_worker_count: 150
resources:
requests:
cpu: 200m
memory: 512Mi
limits:
memory: 1Gi
indexGateway:
replicas: 2
maxUnavailable: 0
resources:
requests:
cpu: 300m
memory: 512Mi
limits:
memory: 1Gi
affinity: {}
chunksCache:
enabled: true
replicas: 1
resultsCache:
enabled: true
replicas: 1
memcached:
enabled: true
memcachedResults:
enabled: true
memcachedChunks:
enabled: true
memcachedFrontend:
enabled: true
memcachedIndexQueries:
enabled: true
memcachedIndexWrites:
enabled: true
minio:
enabled: false
memcachedExporter:
resources:
requests:
cpu: 50m
memory: 64Mi
limits:
memory: 128Mi
  1. Sounds like you’ve checked the distributor and ingester logs and didn’t see anything obvious?
  2. How about CPU and memory? Were distributors and/or ingesters particularly taxed when this is happening?
  3. How often does it happen? Does it happen in correlation to anything else?
Since your gateway is not able to hit the push API endpoint, I think we can say with high confidence that the problem is either the distributor or ingester.
Thanks for the response!
Sorry for a delayed response, so we got this resolved by adding debug log level for Loki components as the following:
We added the extra debug logging output for Loki components in out Loki Helm chart:
runtimeConfig:
configs:
kubearchive:
log-push-request: true
log-push-request-streams: true
log-stream-creation: false
log-duplicate-stream-info: true
And then we were able to see the exact error messages, like:
level=debug ts=2025-09-30T15:25:53.687936029Z caller=http.go:108 org_id=kubearchive msg=“push request failed” code=500 err=“rpc error: code = ResourceExhausted desc = grpc: received message larger than max (5257394 vs. 4194304)”
So we increased our the grpc message sizes as the following:
server:
grpc_server_max_recv_msg_size: 15728640 # 15MB
grpc_server_max_send_msg_size: 15728640
ingester_client:
grpc_client_config:
max_send_msg_size: 15728640 # 15MB
query_scheduler:
grpc_client_config:
Hope this will help somebody with the similar problem.
