24 hours of data (one day) in one SQL row
Dear Friends
I am totally new to Grafana, installed version: 8.3.0.
I have successfully connected to a Postgresql database with data in the following format:
So there are 24 columns for every hour (h0…h24).
Can i use this data structure in Grafana?
I would like to display the 24 hours on the x-axis and the hourly data on the y-axis.
Thank You in advance and sorry for the very newbie question!
Csaba
welcome to the :grafana: forum, @mickeyratt
there are probably many ways to model this data so that you can visualize it in Grafana.
can you please follow these steps to share your raw unformatted data? That way, the community can try and mock up your problem :+1:
