10578 - Raspberry Pi Monitoring
Hi All,
I am trying to figure out where the configurations go for the CPU and GPU temps as per the creator of this dashboard
Collector Configuration Details
[[inputs.file]] files = ["/sys/class/thermal/thermal_zone0/temp"] name_override = "cpu_temperature" data_format = "value" data_type = "integer"
[[inputs.exec]] commands = ["/opt/vc/bin/vcgencmd measure_temp"] name_override = "gpu_temperature" data_format = "grok" grok_patterns = ["%{NUMBER:value:float}"]
I am using telegraf but no idea where to put this?
It is telegraf configuration. See its documentation.
That worked like a charm! Thank you!
I cant seem to get the network dashboard elemets to populate yet but I’ll tinker.
Can you help me with this dashboard? I don’t know what to do. To make it work.
David Kirn
